K5 Blazer 1969-1994
Platform: Truck, GMT 400
Alternators not charging
Old Mar 25, 2012 | 11:52 PM
darknight's Avatar
Default Alternators not charging
I have an 86 Chevy Blazer K 5 Military. I had the (2) alternators rebuilt and installed (2) new batteires. The problem is that the alternators will not charge the battieries. When bench tested the alternators are working, but when hooked up they will not charge the battieres. Any suggestions or help on this issue. I am not sure what else to do at this point. Thank You.
Old Apr 22, 2012 | 4:18 PM
2wd-K5's Avatar
check the wiring to the altornators, the wires should always have power going to them through the main wire that uses the bolt, check for power there
Old Apr 23, 2012 | 9:11 AM
Camaro 69's Avatar
Site Ambassador
Also check the exciter wire (at the plug), it should have power. If that wire or connection to it is broken, your voltage regulator(s) aren't being told to activate.
Ralbon
Jan 2, 2014 8:36 AM
rjenvision
Mar 2, 2012 6:05 PM
JC2133
Feb 19, 2012 11:40 AM
kllawson
Avalanche
Dec 22, 2010 6:31 AM
pervitizm
May 12, 2008 4:58 PM
