K5 Blazer 1969-1994
Platform: Truck, GMT 400
how does the dip stick attach to the pan
Old Sep 30, 2017 | 8:53 PM
selahadams's Avatar
Red face how does the dip stick attach to the pan
on the transmission. Is it pressed on? Or a nut on the inside? Give me a brake......as you can see...I am a female..
Old Oct 1, 2017 | 7:37 AM
kevinkpk's Avatar
It presses in, and should have a bracket attached to trnsmission for support
Old Oct 1, 2017 | 1:43 PM
selahadams's Avatar
Default dip stick
thank you for your kind reply. When you said, press; do you mean by a machine shop? Or can I press it in by hand? thanks for helping me...
Old Oct 1, 2017 | 6:58 PM
kevinkpk's Avatar
Check it, there should be a bracket that screws to the transmission, Physically look/fell for anything that it is attached to. Is it leaking?
