K5 Blazer 1969-1994
Platform: Truck, GMT 400
just curious
Old Apr 2, 2012 | 3:48 PM
John Brazel's Avatar
Default just curious
I have an 84 blazer k5, I am piecing back together slowly but surely. My question is, I have the chevy 10 bolt rear end with 3.42 gears, I have a replacement front axle with 3.73 gears, will this difference in gearing be too much difference. This is no highway vehicle by no means, and will not be driven but maybe twice monthly. It has 44" tractor tires if that would help by any means.
Thanks in advance for any replies.
John
Old Apr 22, 2012 | 4:16 PM
2wd-K5's Avatar
it wont be a problem if it will only be used on slipery surfaces, on another note, having this setup will be detrimental to off road performance, when 4x4ing you want your fron tires to spin faster than your rear, so if your front diff is slower then you will get stuck easier, i wouldnt do this, ring and pinions are cheap
guvner
Jun 30, 2008 9:07 AM
Ahkala
Jun 17, 2008 10:18 AM
Cav#2
Apr 28, 2007 12:40 AM
big_bct
Jun 22, 2006 6:59 AM
