K5 Blazer 1969-1994
Platform: Truck, GMT 400
Manual Trans Advice
Old Sep 4, 2022 | 2:38 PM
BeachGarage's Avatar
Default Manual Trans Advice
In the middle of a body off restoration on a 1970 K5 4WD. Currently an automatic trans truck and I want to change to a manual. I plan to replace original engine with LS3 but not clear on what manual I should drop between the LS and the transfer case. This K5 is on BaT at the moment and below is an image of what looks like a vintage 4 speed trans.https://bringatrailer.com/listing/19...et-blazer-116/
Part number in photos looks like GM 3801137? Any tips on the ideal manual trans I can spec for this build? It can be a modern or vintage. This is my first Chevy truck restoration so I have a lot to learn. Doing al the work myself in my garage btw.
Thanks in advance for any advice
N
Old Sep 6, 2022 | 2:45 AM
oilcanhenry's Avatar
N
Go for a New Process 435GA Transmission, if it will fit. Otherwise I'd opt for a Borg-Warner transmission. They are tough as nails.
mjgord51
Jan 5, 2019 11:31 AM
Falconvan
Sep 6, 2013 7:30 PM
camarocrazy76
Jan 5, 2011 8:30 AM
mrpain
Dec 7, 2009 10:34 PM
vanman
May 13, 2006 1:50 PM
