Chevrolet Malibu
1997 Code p0113
Old Jul 26, 2011 | 10:40 AM
GM Fixer's Avatar
Default 1997 Code p0113
What would cause this to fail? Air Intake Circuit High Input Has anyone had this problem before? Could it be the MAF? or wiring problem?
Old Jul 26, 2011 | 5:56 PM
Tyrod's Avatar
It indicates a problem with the IAT sensor. Could be the sensor, could be the wiring. You're lucky, that's the easiest sensor to change and they're cheap. You'll find it somewhere between the air filter and the throttle body.
Old Jul 27, 2011 | 3:26 PM
GM Fixer's Avatar
ok...thanks
Old Jul 28, 2011 | 10:42 AM
MyBowTieGuy's Avatar
GM Fixer,
For an even more explicit idea as to where this sensor is located, it is key #13 in this '97 Malibu Intake diagram
Cheers mate!
Old Aug 4, 2011 | 4:06 PM
GM Fixer's Avatar
YUP...the P0113 code is still coming up. Harness checks out ok. looks like I am going to have to replace the sensor. IAT.
Old Aug 17, 2011 | 10:49 AM
GM Fixer's Avatar
Double check harness and there was a broken wire, sensor checked out fine
houndog3
Apr 6, 2012 6:24 PM
foxracing254
10
Nov 27, 2011 8:26 AM
American v8
Astro
10
Oct 11, 2010 6:41 AM
sheriff13
Mar 25, 2008 12:55 PM
sheriff13
Mar 25, 2008 12:44 PM
