Astro 1985-2005
Platform: M-Body
1997 chevy asro with a bad OBD2 code scanner plug?
Old Aug 8, 2010 | 1:29 PM
American v8's Avatar
Default 1997 chevy asro with a bad OBD2 code scanner plug?
So I have a 1997 chevy astro (RWD LT 4.6L V6). Recently I had a check engine light come on. So I plugged my code scanner in and nothing happened. no power going to the plug. So I figured thats what the light was for. But when the light went off, the plug still didnt work. Ive never had this problem before. checked all the fuses and they were all good. I also noticed that the light would go off and if you made a shard sudden turn, on went the light. Any help would be great.
Old Aug 9, 2010 | 10:23 AM
ihatemybike's Avatar
Wow, that's a good one. Definitely have a short somewhere, but don't know where I'd begin looking. Guess I try doing a bunch of continuity checks between the ECM and the port and see what I find.
Old Aug 10, 2010 | 6:47 PM
Thanks. Does anyone know if that is a usual problem with these vans?
Old Aug 11, 2010 | 6:06 AM
I've had seven of these vans across 14 years and for several years been on two forums dedicated only to them and four forums with a sub-section for them and do not recall seeing this problem before.
Old Aug 29, 2010 | 12:44 AM
dac1959's Avatar
Default obd II plug
I went to get an emission test last year and when the machine was hooked up to my obdII plug, there was no power @ the plug. Turns out there was a blown fuse, but I don't remember which one. Put a new one in and no problem since.
Old Aug 30, 2010 | 12:31 PM
alka's Avatar
Smile
MY ASTRO 1997 HAS ABOUT 204,000 kMS ON IT , RECENTLY THE ENGINE LIGHT COMES ON WHEN THE GAS TANK IS MORE THAN 1/4 FULL, MEANS WHEN I FILL UP THE TANK IT COMES ON AND GOES AWAYA AS SOON THE GAS IN TANK DROPS TO 1/4 OR LESS TAHN IT, GOT MY FUEL PUMP ( NEW DELCO) CHANGED LAST YR AND HAS ABOUT 10TO 15 THOUSNAD KMS ONLY AFTER IT.
PL. SUGGEST THE SOULTION
Old Sep 7, 2010 | 6:18 AM
Alka, what code does it set? Most parts stores will read the codes for free.
Old Oct 8, 2010 | 7:00 AM
alka's Avatar
Engine code 131 & 136 , pl. tell how to fix and clear these as my emission is due in next two weeks
Old Oct 8, 2010 | 7:04 AM
alka's Avatar
Engine Code 131 & 136 , need to fix problems with Oxygen sensor front or back ( do not know) and some thing with Evaoprator Laek ( got my fuel pump cahnged last year)
Old Oct 8, 2010 | 7:48 AM
alka's Avatar
Pl. solve
