Chevrolet Malibu
2000 Malibu V6
Old Nov 27, 2011 | 8:49 PM
ahmaduhhs's Avatar
Default 2000 Malibu V6
Hello folks, new here to the site. Just bought a used 2000 Malibu with 137k with a V6. Car runs good on the highway but on a red light it has a rough idle almost wants to turn off. I just replaced the oil and filter and did a raditor flush and fill. Order AC Delco fuel filter, PCV valve, Air Filter. What else should i be checking, there is no check engine light on and the engine looks good overall. Thank you in advance for your help.
Old Nov 29, 2011 | 5:44 PM
Tyger's Avatar
Check the plugs, and while you're at it dump a can of BG 44K in the gas tank.
Old Dec 10, 2011 | 6:57 PM
storres6981's Avatar
also check the fuel regulator could be its cloaging up and going to fail soon i had the same probrom changed the filter and it worked for a bit then it will turn off when i stop on a red light checked the fuel regulator and there was no fuel flowing though it should have a little fuel coming in there so i changed it and it worked. just check maybe its the same thing
winterlion
Mar 30, 2013 4:32 PM
Tr39NC
Dec 10, 2006 3:38 AM
rainier
Nov 3, 2006 3:31 PM
tigerstrike363
Nov 1, 2006 8:53 PM
