2001 Malibu wont crank
I have a 01' malibu that turns over but wont start. I was driving it pulled over to go into store and came back out and it wouldn't crank. I have checked codes and it is as follows: U1040, P0103 ,P0171 ,P0300, P0463 and P1189. I wanted to know which ones will cause the car not to start. P300 is for cylinder misfire. Does that mean my heads and ifso does that mean my engine is gone. Will the mass airflow stop it from starting? I need help quick just started a new job and it is not on bus line. Can I get serious replies pls no games.
Thanks so much for caring
https://chevroletforum.com/forum/general-tech-10/obd-p-code-lookup-22799/
scroll thru this list, you should find your codes
The cars turning over, so your not getting one of the three key things, Air, Fuel, Spark. Your prolly getting air.
Can you hear the fuel pump turn on when you crank the key?
supersport1220
December 28th, 2013 8:14 AM
DarnLuck
September 4th, 2008 10:07 PM
Stirgen
February 5th, 2008 3:44 PM
