2001 Tahoe will crank over but wont start
Old Dec 27, 2013 | 7:02 PM
supersport1220's Avatar
Default 2001 Tahoe will crank over but wont start
I have a 2001 Tahoe that I just got back from a transmission shop with a new remand tranny in it. but now it wont start. it'll crank over but wont fire up. when the key is turned to on you can hear the fuel pump prime for about 3-5 seconds then it stops. I turn the key to start and it just cranks. I've also replace the fuel filter and fuel pressure regulator and still no luck. it has 52psi at the shredder valve when you turn the key to on but then starts to drop. Could it be the fuel pump even though you can hear it prime?
Old Dec 28, 2013 | 8:14 AM
Just because you hear the fuel pump running, it does not mean that it has the correct fuel pressure. It could be high for a few seconds and then drop off. You can spray a little bit of gas or starter fluid down the throttle body and if it runs for a few seconds, it ius the fuel pump.
advcomps
Sep 18, 2013 10:22 AM
JOUT22
Mar 8, 2013 3:13 PM
thisnthat
Nov 20, 2012 11:36 AM
2000Impalaspeeder
Astro
Nov 3, 2011 2:48 PM
