Chevrolet Malibu
2002 malibu check engine light
Old Sep 17, 2011 | 9:37 PM
finiteguy's Avatar
Default 2002 malibu check engine light
My 2002 malibu check engine light keeps coming on. The code indicates that the gas cap is not on. I replaced the gas cap, reset the code and it still comes on after a few days of driving. What else could be the problem? Is there a common problem for this model and year?
Old Sep 18, 2011 | 4:26 PM
EinST's Avatar
Welcome to the forum. It would help if you posted the actual code and also your level of mechanical ability. A repair shop will use a professional scan tool and smoke machine to find the leak.
Old Sep 18, 2011 | 9:13 PM
finiteguy's Avatar
The code is P0440
Old Sep 18, 2011 | 9:31 PM
EinST's Avatar
That code says a weak vacuum condition. It could be a large leak (larger than a pinhole) between the fuel fill cap and the purge solenoid. It could also be a blocked purge line (lack of intake manifold vacuum). I don't know about you but I myself would take it in to get it serviced. Good luck.
redrotor
Cobalt
Aug 29, 2019 8:38 PM
Apenas83
Mar 15, 2011 6:44 PM
ilovefox
Oct 22, 2009 11:40 PM
James0816
Mar 5, 2008 4:12 PM
jen6721
Jun 11, 2007 4:13 PM
