Chevrolet Malibu
2002 Malibu dash trim
Old Jul 14, 2010 | 10:09 PM
Ukulele's Avatar
Question 2002 Malibu dash trim
I need to replace a part of the dash that extends the top center a/c duct to the dashboard trim. It holds the two center a/c vents and the hazard flasher/switch. I gather that it's attached to the trim plate (that has the Malibu badge on the passenger side end) by two screws but I haven't pried the trim plate off yet. I can see that it's not molded onto the main dashboard structure.
The duct extension is broken and the hazard flasher is just kind of sitting on the pieces that are left. The left center a/c vent is no longer attached on the left end so it just flops around. I recently inherited this car and have no idea what Dad did to break it, but I need to replace the duct extension.
I don't know what the part is called, if it's available as a separate part, or if it's included with the trim plate which does not appear to be damaged. The dealer has no idea, either. They'll just order whatever I tell them I need.
GMPartsDirect.com shows the trim piece and calls it a "Cluster trim W/o Is". There are three versions of the part "Cluster Trim", one W/o Is and two W/Is. What's an Is and does it have anything to do with the duct extension piece? Can I buy just the duct extension?
Does anyone understand the part I'm trying to describe and know how I can get a new one with or without replacing the trim plate?
Thanks for any help you can offer.
Old Jul 14, 2010 | 10:26 PM
Ukulele's Avatar
Oops. I found another parts site that describes the Cluster Trim as with or without LS (not Is). This is a Malibu LS but the trim plate only says Malibu. It's wood grained if that matters and I don't see any gold trim or where gold trim might be an option. The three options for the trim plate are:
Cluster Trim w/o LS for about $150
Cluster Trim w/LS with gold option for about $75
Cluster Trim w/LS without gold option for about $250!
What's the difference and are they interchangeable?
anunez
Jan 7, 2008 10:30 PM
eric2007ltz
Apr 27, 2007 5:33 AM
TEAM CHEVY
Aug 13, 2006 11:38 PM
