Chevrolet Malibu
2004 Malibu battery light
Old Dec 26, 2014 | 5:41 PM
Ohfudge's Avatar
Default 2004 Malibu battery light
I have a 2004 Malibu LT (3.5).
It has 130k miles on it. I recently got the spark plugs and wires replaced presumably for the first time(not original owner).
After I got the car back from the mechanic, I noticed the battery light started coming on when I accelerate fast, particularly uphill. Last night I noticed while the battery light is on, the power steering becomes temporarily disabled and the lights dimmed once. The mechanic load tested the electrical system while I revved the car to 4k rpms and no battery light at all.
Any suggestions? I know the power steering assembly had issues and is under recall, I haven't had it replaced yet but I will this next week. Could that be causing this? Any help is appreciated.
Old Feb 2, 2015 | 4:40 AM
2005equinox's Avatar
Check the wires going from the battery for corrosion inside the red plastic that is molded around them. I just disconnected the positive wire and flexed the wires and the corroded material just worked its way out. I haven't had the battery light come on since. Another sympton that I experienced was the anti-lock brake warning light would come on also. That was with a 2000 Malibu LS.
Old Sep 3, 2015 | 9:17 PM
Maxxxx's Avatar
Default Re: Malibu Battery Light
I have a situation similar to yours. My 06 Malibu Maxx LT,with about 60 K miles, during hard acceleration, will display the battery light and the power steering will momentarily cut out. It happens very quickly and disappears just as quickly as I back off the gas. I was able to graph system voltage with a scan tool during the event where the voltage spikes to 16 from approximately 13.7, never dropping below this.
Also, spark plugs and wires were changed coincidently.
The L terminal wire passes close by the coil pack.
I wonder if it's possible that some type of interference from the new plug wires or the coil pack is influencing the signal between the ECM and the alternator/regulator?
I have cleaned and secured as many grounds as I could access so far and the battery terminals.
The alternator has also been replaced with OE new unit. Problem persists but occurs less frequently.
kllawson
Avalanche
Dec 22, 2010 6:31 AM
Igotasilveradonstuff
Dec 8, 2010 12:55 PM
Sirius018
Jul 17, 2010 10:10 AM
Howard80633
Oct 26, 2008 10:45 PM
rwrows
Apr 6, 2008 12:04 PM
