Chevrolet Malibu
2005 Chevy Malibu Engine Replacement
Old May 22, 2022 | 9:13 PM
jciepluch's Avatar
Post 2005 Chevy Malibu Engine Replacement
I have a seized motor and am looking to replace the motor with a fresh one. What is the easiest way to swap out the motor. I have seen 2 options in my research. Option 1: I can drop the entire front drive train out the bottom of the car. Option 2: I can detach the motor from the transmission and lift the motor only up out the top.
Does anyone have any experience pulling a motor from an 05 Malibu. Should I drop everything out the bottom or pull only the motor from the top?
Old May 23, 2022 | 9:58 AM
oilcanhenry's Avatar
Needless to say but unless you can or have a way to lift the car up the only manner is hoisting the motor up and out or I suppose if you can find a place lower than ground level and wide enough then you could remove it down the bottom if nothing interferes with that.procedure.
Old May 23, 2022 | 7:30 PM
jciepluch's Avatar
Default Car lift/ engine lift
I have a car lift and an engine cherry picker. So both options are do-able. I am just looking for some info/experience on which is easier.
Old May 27, 2022 | 8:03 PM
Well, have more than I currently have. I think that the main issue is making sure nothing is going to be an obstruction. I would go with the cherry picker, but I am old-school, so that's how we did it back in the day. Just have to get all those extra wires out of the way.
lonewolf04
Nova & Chevy II
Nov 5, 2011 7:45 PM
Clem210
Jul 24, 2011 11:56 AM
JCassidy0203
May 17, 2009 1:50 PM
Duramax742
Dec 9, 2008 11:22 PM
GlitchMobile
Jun 8, 2008 9:07 AM
