Chevrolet Malibu
2008 Malibu 2.4L PO420 help
Old Jun 17, 2015 | 4:31 PM
e5husmc's Avatar
Default 2008 Malibu 2.4L PO420 help
Wife's car is showing PO420. Here are the test results:
Vehicle Manufacturer: Chevrolet
Vehicle Calibration ID: 126
Test report:
MID:$01 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
Max: 0.55022V Min: 0.55022V
Test result value: 0.55022V
PASS
MID:$01 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
PASS
MID:$01 TID:$03
Low sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0.45018V Min: 0.45018V
Test result value: 0.45018V
PASS
MID:$01 TID:$04
High sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0.65026V Min: 0.65026V
Test result value: 0.65026V
PASS
MID:$01 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 1
Max: 99ms Min: 0ms
Test result value: 12ms
PASS
MID:$01 TID:$06
Lean to Rich sensor switch time(calculated) - O2 Bank 1 Sensor 1
Max: 120ms Min: 0ms
Test result value: 9ms
PASS
MID:$01 TID:$80
Max: 65,535Changes Min: 30Changes
Test result value: 278Changes
PASS
MID:$01 TID:$81
PASS
MID:$02 TID:$8a
- O2 Bank 1 Sensor 2
Max: 800Count Min: 0Count
Test result value: 46Count
PASS
MID:$02 TID:$8b
Max: 1.10068V Min: 0.77531V
Test result value: 0.77665V
PASS
MID:$02 TID:$8c
Max: 0.10004V Min: 0V
Test result value: 0.08772V
PASS
MID:$02 TID:$91
Max: 0.45018V Min: 0V
Test result value: 0.40541V
PASS
MID:$02 TID:$92
Max: 1.10068V Min: 0.55022V
Test result value: 0.55193V
PASS
MID:$02 TID:$93
Max: 7 Min: 0
Test result value: 0.68
PASS
MID:$21 TID:$4d
- Catalyst Monitor Bank 1
Max: 0mHz Min: 4,177mHz
Test result value: 19,744mHz
FAIL
MID:$21 TID:$a0
Max: 0.99939 Min: 0.49971
Test result value: 0.33434
FAIL
MID:$3a TID:$c0
- EVAP Monitor (cap off)
Max: 30L Min: 0L
Test result value: 5.836L
PASS
MID:$3a TID:$c1
Test incomplete or dependant test failed
MID:$3c TID:$c8
- EVAP Monitor (0.040")
Max: 0.64843Ratio Min: 0Ratio
Test result value: 0.00781Ratio
PASS
MID:$3c TID:$c9
Max: 0.72655Ratio Min: 0Ratio
Test result value: 0.1289Ratio
PASS
MID:$3c TID:$ca
Max: 1Count Min: 0Count
Test result value: 0Count
PASS
MID:$3c TID:$cb
PASS
MID:$3d TID:$c4
- EVAP Monitor (0.020")
Max: 6,553.5S Min: 100S
Test result value: 100S
PASS
MID:$3d TID:$c5
Max: 2,500Pa Min: -8,000Pa
Test result value: 63Pa
PASS
MID:$3d TID:$c6
Max: 60S Min: 0S
Test result value: 2.8S
PASS
MID:$3d TID:$c7
Max: 40L Min: 10L
Test result value: 10.009L
PASS
MID:$41 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 8Count Min: 0Count
PASS
MID:$41 TID:$d3
Max: 2.001 Min: -3
Test result value: 0.182
PASS
MID:$42 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 2
PASS
MID:$42 TID:$d3
Max: 2.481 Min: -4.199
Test result value: -0.544
PASS
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
Test result value: 2Count
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
Test result value: 4Count
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
Test result value: 1Count
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$c1 TID:$19
Max: 12,292 Min: 10,544
Test result value: 13,280
FAIL
MID:$c8 TID:$30
Max: 409.70001 Min: 5,641.7002
Test result value: 2,893.1001
FAIL
MID:$e1 TID:$19
Manufacturer defined MID -
Max: 41,190 Min: 4,144
Test result value: 6,624
PASS
MID:$e1 TID:$8d
Max: 1.25062inch Min: 0.31818inch
Test result value: 0.40504inch
PASS
End of report.
Is this a bad O2 sensor or Cat?
Thanks
jtlonghorn
Jan 18, 2012 11:29 PM
chevyguy123
Dec 6, 2011 3:40 PM
jgray152
Jul 10, 2010 10:15 PM
Sammyj
Mar 6, 2008 5:07 AM
shadetreemech
Jan 30, 2008 4:44 PM
