Chevrolet Malibu
2009 Malibu 2.4L Acceleration Loss.
Old Dec 7, 2018 | 6:15 AM
jakodemus@gmail.com's Avatar
Default 2009 Malibu 2.4L Acceleration Loss.
Best scenario for occurrence:
  • 1st 20-40% of 1 hr drive.
  • 40mph+ (Rarely observed at low speed)
  • light accel to maintain speed up a slight grade on the freeway
Details:
  • Complete acceleration loss
    • RPMs drop to zero and back to normal in fraction of a second causing jolt/hesitation, sometimes in rapid succession 2x-3x.
    • twice had complete loss without any accel recovery where pedal no longer functioned. Had to coast to shoulder, shut off, turn on. Engine idled normally during that.
Repairs completed
  • spark plugs and boots replaced
    • progressively worse leading up to replacement
    • fewer occurrences after replacement, but now progressively getting worse again and has been 5 driving days since replacement.
  • Whole can of Seafoam added, no changes.
  • No check engine lights. Unsure if any codes thrown.
Old Dec 8, 2018 | 5:28 PM
oilcanhenry's Avatar
Details:
Repairs completed
Some things dont throw an OBDII code. Did you check fuel pressure yet? If you have a fuel filter on the frame install a new one ( not a Fram). Could be TPS but that should throw a code.How many miles do you have?
Old Dec 9, 2018 | 12:25 AM
not checked yet. I’ll likely leave it with a garage again for a week at least this time. Will certainly recommend the cheaper thinks to check first. Another odd thing I’ve noticed is the accel fail happens more when I’m going up a slope as opposed to just giving it gas on a flat stretch. If it’s a filter why would it be fixed temporarily just from cycling car off and on?
Thanks for some ideas.
Old Dec 9, 2018 | 5:37 PM
Its not likely the filter, but if it hasnt been changed in a a while it wont hurt. You want to have the pump putting out maximum pressure, when you test the fuel pressure.
