Chevrolet Malibu
2015 Malibu 2.5 engine runs and dies.
Old May 21, 2024 | 4:42 PM
boilermaker27's Avatar
Default 2015 Malibu 2.5 engine runs and dies.
I have a 2015 Malibu with the 2.5 engine. I have been having problems with the engine suddenly running very rough and then dying. The engine starts with no problems, a few minutes later the engine get's very noisy and shakes the whole car and then it dies. It sometimes does it when driving slowly but at highway speeds it never does it. I just cleaned the mass air sensor and also put on a new throttle body. Previously I changed the o2 sensor bank 1 and also changed the vacuum line that runs from the plastic line from the air cleaner and throttle body to the two outlets on the valve cover. I did get two codes a while back one was for a lean mixture and the other vacuum leak. I checked all the vacuum lines, plus I did change the o2 sensor. Any ideas of what to do next? I failed to mention that the engine runs smoothly most of the time but this can occur any time when driving slowly and especially at start up when the engine starts to warm up.
Old May 21, 2024 | 5:06 PM
do some fuel pressure tests
Old Jun 22, 2025 | 8:31 PM
KobeMillz's Avatar
Im having the same issue, it usually has problems in idle, itll shake then go into reduced engine power mode and after it will shut off. Have you fixed it?
LilMsPris
Jul 18, 2023 1:50 AM
Terry500
Sep 12, 2021 8:50 PM
Arriell Perry
Sep 30, 2019 11:46 AM
howie1976
Aug 10, 2017 11:16 PM
vmx120
Sep 15, 2005 9:10 AM
