Chevrolet Malibu
2018 Chevrolet Malibu
Old Jun 13, 2018 | 6:45 PM
briblo1982's Avatar
Default 2018 Chevrolet Malibu
When I Shift my car into park it makes a grinding noise. Is that normal or bad?
Old Jun 13, 2018 | 6:46 PM
briblo1982's Avatar
it doesn't do on any other gears N, L, D, none of those.
Old Jun 14, 2018 | 2:28 AM
oilcanhenry's Avatar
Not normal. Likely a bad Sprag gear. Should be covered on warranty.
Old Jun 14, 2018 | 3:11 PM
kountzkj's Avatar
Just curious. How do you like the auto/stop feature on your 2018 Malibu. I hate the damn thing, and consider it a safety hazard. I would appreciate your comments.
Old Jun 14, 2018 | 3:40 PM
briblo1982's Avatar
I dont really care for it. I’m wondering if there is way to bypass it or disable it. They should you that option
Old Jun 15, 2018 | 4:16 AM
I agree, but GM does this to meet CAFE standards and auto-stop helps that. You can learn to feather the brake at a stop so it doesn't shut down the motor.
I would advise NOT trying to disable auto-stop while on manufacturers warranty. Feathering the brakes can make those brake pads last longer too. Too many people are slamming the brakes HARD at stops, and accelerating up to speed way too fast, IMO. That's also hard on the entire motor, drive-train and brakes. I guess some people have lots of money to burn.
Not exactly the best way to save gasoline or make your brakes last a long time. Gas is EXPENSIVE nowadays, so why waste it unless you are racing someone??.
Also tailgating is way out of bounds these days. At highway speeds that alone can cause an accident and might even get someone killed. It that really worth it?
Old Aug 27, 2019 | 1:14 PM
Kathy Mahan's Avatar
You can also bypass by driving in L gear and manually putting into 6th gear
