Chevrolet Malibu
99 Malibu hard start and rough idle
Old Sep 30, 2014 | 4:19 AM
akfisherman22's Avatar
Default 99 Malibu hard start and rough idle
I got two problems that may or may not be related. If the car sits for more than 10 minutes than it has a hard time starting. I can turn it off and on and it starts right up. Next probelm is rough idle when in gear. If i shift to neutral it runs smooth. Runs normal when accelerated and my mpg are normal. Recently replaced plugs and wires and fuel pressure regulator.
Old Sep 30, 2014 | 11:07 AM
The hard starting is probably the check valve in the fuel pump is bad. It takes a while to build up pressure when the fuel in the line drains back into the tank when the pump is not running. The rough idle may also be caused by a slightly weak fuel pump.
99cummins
Dec 10, 2013 8:44 PM
runninlope
Dec 3, 2010 8:52 PM
Chevyboy28
Oct 4, 2010 4:40 PM
19dabeast85
Jul 15, 2010 10:08 PM
dbapcp
Apr 25, 2008 4:30 AM
