Check Gas Cap Light
the check gas cap light sets for a large evaporative emission system leak. The car sees the fuel level change when you refill upon start up. The evap monitor runs a leak check and if it detects a large leak...thinks you left the gas cap off....but the leak could be anywhere in the system. You could have the fault code read with a scan tool and try to follow a diagnostic procedure for that code...or Have a shop leak test it.
