Chevrolet Malibu
coolant lose 2000 3.1
Old Aug 20, 2011 | 11:33 AM
SkagitHunter's Avatar
Default coolant lose 2000 3.1
I have a 2000 with a 3.1
I have replaced the radiator, water pump. But still loosing coolant. I think it comming out the overflow because of the marks on the hood flung by alternator.
The temp runs between 3/8 to just over half in city traffic. The LIM gasket was changed before I got it.
The stock waterpump had a huge impeller, The after market has alot smaller impeller?
At what temp should the fan come on ?
It runs like a top. at stop lights it hard to tell it's even running.
No water in the oil. was tested at overflow with head gasket tester.
The temp guage works....has been to 3/4 when waterpump went out.
Was pressure tested...no leaks
Old Aug 20, 2011 | 9:33 PM
Help!!!!!:d
Old Aug 24, 2011 | 5:39 AM
DHoShow's Avatar
Cap pressure tested?
Old Aug 24, 2011 | 8:23 AM
kevinkpk's Avatar
You can get a pump that replaces the radiator cap, pressure the system up, then look for leaks.
Old Aug 24, 2011 | 4:28 PM
DHoShow's Avatar
Looks like OP said that he already did that man
Old Aug 24, 2011 | 7:59 PM
kevinkpk's Avatar
Thanks for recognizing me as a human being. I missed his last sentence. I'd suggest since it has been pressure tested, and he feels it is the overflow, I think if he filled the overflow up with water too see if it has a leak. Since the pump/tester I was refering too takes out the overflow nipple.
rosencra38
Dec 20, 2011 5:28 AM
ed1le
Apr 17, 2010 7:41 AM
tech12volt
Colorado
Feb 18, 2007 4:13 PM
