Dash and steering wheel shaking at stoplight
Hello everyone I've got some problems with this just purshased 2004 classic 2.2 auto . When I put the car in gear with foot on brake you can feel a vibration in the steering wheel and the dash vibrates not too terrible sometimes but sometimes it does shake pretty good say when you pull up to stoplight. It always shakes some , but sometimes shake bad. Is this something someone has encounterd before ? I thought I would ask before I tear into the dash to look for some loose bolts or start changing some pricy motor mounts. Thanks raffterman
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Sorry to hear you've been experiencing this, raffterman! If you'd like us to look into the matter further for you, please send us a direct message with your VIN. Have you thought about bringing your Chevy to a dealership for a diagnosis?
Best,
Katie (Assisting Louis)
Chevrolet Customer Service
Best,
Former Sponsor
Have you checked your Chevrolet Classic Brake Rotor? Is it warped? If so, then change it; otherwise the only cause for this problem is Engine Mount. Check and replace it.
The engine mounts are new also
Steering wheel and dashboard vibrates when stopped
2004 Chevrolet Malibu 2.2 liter engine automatic transmission.
Drives very good!
When stopping at traffic light steering wheel and dashboard vibrates.
Changed Front Rotors and pads also REAR shoes
Motor mount are all good.
Drives very good!
hondaman74
September 1st, 2012 11:16 PM
arm425425
February 16th, 2011 10:10 PM
