Death trap
Death trap
My 2013 Chevy Malibu has so many issues right now and I wish I’d done the research on this car before I purchased it, first thing tomorrow morning I will be contacting an attorney because the bill Kay dealership that I went to knew this car had issues. The stabiltrac light won’t go off, the traction light and check engine light is now on and my car won’t go over 20 mph and the engine overdrive light is on now. When I visited the Gm forum I see may problems like this from multiple people but no answers on how to fix it. GM should make better cars or at least make sure the problems are fixed before you resale them
The reason the vehicle will not go over 20 MPH ,very well could be the system is in "Limp Mode" .That mode allows the operator to get to a service facility. It is also to prevent any damage to vehicle components.
There could be many reasons as to why it is in limp mode, and that is when a good tech will need to check it out and determine just what is going on. It could be something simple , but some special test equipment and access to information may be required and certainly a knowledgeable mechanic.
Patience,,, usually ,if available , pays off in circumstances like this.
Unless you have some extended warranty what's wrong with using a good independent shop? You can use Yelp to find one easily. That said perhaps you can have your Malibu repaired at a dealership, not on strike. Might be a ways away, but if it eases your mind, it might be worth the extra miles. Why are you calling the Malibu a "Death Trap"? What did it do to deserve that?
hogbiker (August 17th, 2021)
acamp88
Cobalt
14
May 23rd, 2024 1:33 PM
