Chevrolet Malibu
location of A/C drain outlet on 2007 Malibu
Old Jul 19, 2018 | 11:21 AM
ericpsu's Avatar
Newly Registered
Default location of A/C drain outlet on 2007 Malibu
I need to find the A/C drain outlet on our Malibu. The front passenger rug gets soaked from the A/C. This happens when we go around a corner after the car has been running with the A/C on. You can the water slosh then it starts running out. Need to clear the line before vacation and can put it on a rack tonight to get to it.
Thank You
Old Jul 19, 2018 | 11:45 PM
oilcanhenry's Avatar
Thank You
There should be a small drain hose near the bottom of the firewall, most likely on the passenger(R) side or closer to the middle. That's where the A/C evaporator, under the dashboard, drains out the humidity/condensation onto the ground from the HVAC box.
Might be you can run a "snake"/or small tool like a small spring up there to clear it out, just like the plumbing in a house. Try not to force it back up, as you dont want it to clog up again with whatever it is that is not allowing your A/C box to drain properly.
