Chevrolet Malibu
Malibu 2009, reset oil life
Old Apr 8, 2012 | 12:19 PM
black bear 84's Avatar
Default Malibu 2009, reset oil life
Hi guys,
I need help, I have changed the oil, filter, lube in the car, and I wanted to reset the oil life.
Following the instructions on the owner's manual in page 5-25, does not change the reading, the message is still "oil life 8%"
Please help
Black Bear
Old Apr 8, 2012 | 12:21 PM
I have to do it several times. Keep trying.
Old Apr 9, 2012 | 8:17 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> black bear 84,
1. Display OIL LIFE RESET on the DIC.
2. Press and hold the INFO & the ENTER (<-) buttons for at least one second, let go. OIL LIFE RESET will display, hit ENTER (<-) button again and an ACKNOWLEDGED display message will appear for three seconds or until the next button is pressed. This tells you the system has been reset.
3. Turn the key to LOCK/OFF.
If the CHANGE OIL SOON message comes back on when the vehicle is started, the engine oil life system has not reset. Repeat the procedure.
If you have any additional questions, please feel free to contact me.
Louis
GM Customer Service
joelena
Oct 18, 2008 11:40 AM
Twobitt
Aug 15, 2007 12:25 PM
Mercpuman
Jul 11, 2007 7:02 PM
readyman
Jun 30, 2007 5:10 PM
