no start
I’m new to this forum ,I have a 2011 malibu ls 2.4 the other day I was driving and slowed down to cross a rough railroad crossing and the car stalled on me when I went to restart it just turned over with no sign of starting,I had to tow it home .
Put a code reader on it and said it was camshaft position sensor ,changed them it still does the same thing ,fuel pump does kick in ,Would the fuel pump relay have anything to do with it ????????????
If you hear the fuel pump kick in as you stated then the relay is working. Did you do a fuel pressure check to see if the pump is working properly? You said you changed them, how many sensors did you change?
