Chevrolet Malibu
P0826 shift code
Old Nov 19, 2018 | 3:59 PM
04malimaxx's Avatar
Default P0826 shift code
Hello all. I’ve had this code since I bought the car, and I am assuming it is because the manual up and down shift buttons do not operate. Other than chasing wires, is there anything right off the bat that makes these malfunction causing this code? A dirty switch? Loose wire? I just want to hit the basics before I go having to replace/chase wires around. This is on a 2004 Malibu Maxx LS V6.
Old Nov 24, 2018 | 2:28 AM
oilcanhenry's Avatar
Someone probably spilled something like soda on the shifter. I'd pull the battery, get some VERY hot water and soak all that bitch down good. You will have to wait until its dry to hook up the battery. If that doesn't work try some contact .cleaner on it.
Old Nov 24, 2018 | 8:49 PM
04malimaxx's Avatar
Thanks I’ll take a look and see what’s up with the wires and contacts.
