Chevrolet Malibu
reduced power mode
Old Oct 27, 2023 | 4:15 PM
KevinRHutch's Avatar
Default reduced power mode
2013 Chevy Malibu Eco
Have a 2013 Chevy Malibu Eco, recently the car goes directly into reduced power mode. I have check the codes and the fuel pressure regulator was faulted and the cam position sensors were not correlating. Replaced the fuel pressure regulator and the high pressure pump but still no change. The issue is not low pressure, it is way high. At Idle it is reaching 3,000 psi. With terrible idle issues and a screeching noise do to the injectors being overridden by the pressure. I have yet to replace the cam sensors but have replaced the actuators. The other issue is at idle the timing is hovering at zero, at 2,000 - 2,500 it is giving close to 60° of advance. I wonder if it is the sensors or the phaser or what?
Old Oct 27, 2023 | 6:41 PM
what are the full codes please?
Old Oct 28, 2023 | 9:48 AM
Default Full codes
I'm not around the car at the moment but I will update those for anyone going through the same issues. In the meantime I will give you the diagnosis. I found the right side guide for the timing chain to be broken and the car had indeed jumped time. Luckily I don't believe any valves have collided with pistons but remains to be seen. I will change the timing chain, guides and tensioner tonight and will update tomorrow.
Old Oct 30, 2023 | 5:27 AM
Default Update
● Update, I did change the timing chain, tensioner and guide. The car runs like a sewing machine now. I did not write the codes down but from what I remember it had 4 verified codes and a few that were just set because of me unplugging and plugging back in sensors. 0011, 0016, 0028 and I think the other was 0064 or something like that. Do not hold me to those numbers, that was from memory and could be wrong. Main thing I take away from this is if these 2.4's start setting solenoid and cam sensor codes I'm looking directly at the black chain guide before anything else! Hope this helps someone!
Old Oct 30, 2023 | 4:51 PM
Thanks for posting the solution
Brian17
Jan 31, 2023 8:44 PM
dmoses
Dec 10, 2019 12:48 PM
Rkn
Jun 15, 2015 11:32 PM
Rvinyl.com
Jan 22, 2014 1:34 PM
