Chevrolet Malibu
Severe Misfire
Old Mar 27, 2016 | 4:51 PM
TexasJoe1912's Avatar
Default Severe Misfire
I have an 06 malibu ss, 3.9L, i just recently changed the spark plugs 1,3, and 5. The numbers 2,4, and 6 are changed as well, but when the engine runs at idle for a minute or so, the traction control light comes on and the check engine light flashes. Anybody know what my issue is, i have a code that the fuel sending unit has high voltage output, was running fine before I changed the plug, theres a knock every few seconds and then runs smooth and knocks a few times and repeats that pattern.
Old Mar 27, 2016 | 5:35 PM
post the actual code
did you remove the intake to access the plugs? vacuum line off the fpr?
Old Mar 27, 2016 | 5:48 PM
Default Dtc
P0171
P0463
These were the codes already showing before change, i dont have a code reader right now
Old Mar 27, 2016 | 5:55 PM
I did not remove the plenum, but the air intake, i disconnected battery, so I could unplug the rear O2 sensore and the electronic distributor sensor and the,intake sensor as well as the connections to the alternator to pull the,harness out of the way, and I took off by accident the plastic vacuum line that connects to the intake into the cylinder head
