Chevrolet Malibu
Starting Issues
Old May 6, 2012 | 11:48 PM
jrode's Avatar
Default Starting Issues
My girlfriend has a 99 malibu. it will not start in the mornings or late at night. During the middle of the day it starts fine. The check engine light is on and i checked it and it said it was a faulty IAC valve and a pin stuck on the EGR valve. I replaced the IAC valve cause i could see if it was the wrong air flow that causing it. I have changed the plugs checked the wires to see if they had a brake in them any where by misting water on them while it was running and looking for spark and did not see anything there. It seems as if something is getting moisture in it to me but i cant find what. The part that really has me baffled is that when it will not fire if i open up the hood and disconnect the spark plug wires off of coil 2-5 and go back and try to start it it will start. there is spark at that coil after it starts. shut it down hook them back up and go back and it will start up and run. i can not figure out what is going on with it. Please if anyone has any ideas of what else to look for or something to try please let me know. I have got to get this car back up and running.
thanks again
Jeremy
Old May 6, 2012 | 11:50 PM
jrode's Avatar
A little more information for got to add. The car sat for about a year. prior to us getting and and trying to get it back in running order for her to drive. it is a 99 malibu with the v6 motor
joshm
16
Feb 9, 2015 12:07 PM
SS70Chev
Dec 13, 2006 2:40 PM
joshm
Dec 11, 2006 11:54 PM
UKChevyJules
Dec 6, 2006 2:26 PM
