Strange Random Question
hi, I have a 06 Malibu, i would like to change out my radio system for something a little smarter, while there is this adapter from metra, its not the solution that I want, basically, i want to put in a custom car PC that I want to emulate the stock radio software/firmware, is there a way to capture the code that lies within the radio itself in way that i would be able to emulate/manipulate it in a PC environment? I know its kind of a long stretch and not the simplest solution, but hey, i like a challenge every once in a while. Thanks in advance for your help
Unless you can write your own program from scratch, and you know where the parameters are in each unit you will not be able nor capable to do this. If you can then this is more than likely a possibility. However, I would almost certainly agree with Brett on this one. Good luck.
Hope it helps.
Stocked88
August 31st, 2015 4:04 PM
