Chevrolet Malibu
window/door lock switch removal
Old Sep 15, 2010 | 10:32 AM
Roy Sutherland's Avatar
Default window/door lock switch removal
How do you remove the window/door lock switch assembly on a 2005 Chevy Malibu?
Old Sep 16, 2010 | 5:30 AM
mattdez's Avatar
Pull the entire panel off the door and you'll be able to get it removed from the back side of the panel.
Old Sep 17, 2010 | 7:10 AM
Thanks, when removing the door panel, I can only locate two screws after removing the plastic cover behind the 'door closer bar', a little below the middle of the door. Do you know if these are the only screws I need to remove?
Master Blaster
Jan 17, 2015 5:34 PM
Bogeymanmcs
Sep 1, 2010 9:27 AM
Mastiff
Jul 12, 2010 8:39 PM
davbell22602
Mar 10, 2010 8:36 PM
cnterline
Mar 16, 2009 4:35 PM
