Chevrolet Malibu
Window won't go up...
Old Dec 19, 2007 | 4:27 PM
RugerBob's Avatar
Default Window won't go up...
Hi all, 1st post. I have a 2004 malibu and when the wife was driving to work this morning she rolled the passenger window down a few inches. She could not get it to go back up. I met her at the store and tried to help it up, no luck. So , I let her take my Impala and drove hers. At lunch I looked into it. I have 12-13 volts at window switch.I took the switch out and did a continuity check on switch to see what wire was activated by switch. No luck with jumping it. I did all this at passenger door switch. She rolled it down from drivers side. The window will go down but not up. I don't know how to remove door panels. Do I need a book? Since she did it from drivers side do I need to look into that side? Since the motor will go down,do I need to look at that? Any Ideas from you other Malibu owners? We got alot of snow and its cold here in Maine, so any advice is greatly appreciated. Thanks Bob
Old Dec 19, 2007 | 5:06 PM
EvansBlue's Avatar
Default RE: Window won't go up...
You should be able to pry the panels off as they are held on by clips. Then if you can't seem to get to the bolts holding the motor in, there are 3 indetions directly in front of the bolts on the window motor you are supposed to drill into so you can get a socket on the bolts behind..
websightmaster
Apr 23, 2022 9:37 PM
justin69
Feb 28, 2015 2:54 PM
1LooseLugNut
Aug 15, 2010 6:18 PM
davbell22602
Mar 10, 2010 8:36 PM
majictiger
Astro
Apr 10, 2009 7:34 PM
