Chevrolet Malibu
won"t start
Old Nov 28, 2017 | 12:49 PM
austinsiron's Avatar
Default won"t start
05 malibu classic. will not start. had starter tested and it"s good. battery is good. every time i try to crank the starter will click then all gauges and radio reset. all fuses look good. anybody have any suggestions that don"t involve taking it to a shop?
Old Nov 28, 2017 | 2:35 PM
Check your cables to the battery at both ends for corrosion or looseness. How do you know the battery is good. How did you test it?
Old Nov 28, 2017 | 3:32 PM
kevinkpk's Avatar
I agree, how old is the battery, and how was it tested?
Old Nov 28, 2017 | 5:47 PM
Default Still working
The battery is three years old. I have checked every cable. I have a digital battery tester/charger
Old Nov 29, 2017 | 8:37 AM
speedOhead's Avatar
either lose battery terminals or bad ignition switch
Old Nov 29, 2017 | 12:37 PM
Rednucleus's Avatar
Has the battery been load tested?
Old Nov 29, 2017 | 3:18 PM
kevinkpk's Avatar
Can it do a min max on the voltage during crank? If the voltage is dropping below 7-8 volts, replace the bbattery, what I am reading still points to the battery.
