1990 Lumina 3.1 issue
I have a 90 model lumina euro with the 3.1, a while back I had an issue with the car acting up & and running bad & dying when putting it in gear, check engine light came on, being odb 1 i jumpered the diag port to get the code... gave me a code 34, Map sensor low voltage i do believe, I replaced the map sensor with a new one, acted same way & gives me same code, however if i leave the pigtail unplugged from the map sensor, the car runs great, but of course the check engine light is on all the time....
what could the issue be?????
vaccum leak or a bad pig tail maybe ????
please help
please help
please help
please help
exact code meaning
yes all i get is a code 34 which means
34- manifold absolute pressure (map) sensor signal voltage low
that is the odb 1 meaning for the code on this car
also with the pigtail unplugged the car runs GREAT... NO issues what so ever
but the minute i plug it in when I start the car and give it gas it will die then
the car it will run and drive up to only 25 mph and then start bucking, like a fuel issue. the code is why i replaced the MAP sensor, like i said the new one acts & the does the exact same, and gives the same code, but with it unplugged it's like nothing is wrong, so thats why i am trying to figure out WTF it is...
Last edited by Michael Cannaday; October 8th, 2012 at 2:45 PM. Reason: forgot some text
