Platform: A-, G-, & W-body
1996 Lumina 3.1 Stalling Issues
Old Jun 12, 2013 | 12:12 AM
NycRon's Avatar
Default 1996 Lumina 3.1 Stalling Issues
My issue is that my car keeps shutting off when I'm on the brakes to long or at the light for to long. It can't idle longer then 2-3 minutes. The air sensor was replaced. I had somebody tell me it was the main computer at fault. So I replaced the computer, and the service light went off and the car worked great, it stopped stalling and I could idle fine. But out of nowhere after two hours of driving the service light came back on and the car started stalling once again. So I thought I would finally ask for help online. Thank you
Old Jun 25, 2013 | 9:10 PM
go-part's Avatar
Former Sponsor
Why Does a Car Stall When You Brake? | eHow
Check for vacuum leaks.
Old Sep 23, 2013 | 2:27 PM
WyrTwister's Avatar
Originally Posted by go-part
And / or loose , defective , or otherwise messed up sensors , wiring or connecters .
But you hit it right on the head , brakes -> more likely vacuum problem .
My 96 Lumina ( when I started tracing down vacuum lines ) proved to have an absent vacuum reservoir ! No answer for that , I bought the car used in the late 1990's .
God bless
Wyr
Old Dec 4, 2013 | 2:36 PM
sledge.impy's Avatar
My 96 Lumina ( when I started tracing down vacuum lines ) proved to have an absent vacuum reservoir ! No answer for that , I bought the care used in the late 1990's .
God bless
Wyr
Agree with the vacuum issues. I once knocked off hose to the fuel purge canister! oops!
original poster should look for dry rotted vacuum lines too.
Danman2897
Nov 1, 2012 4:26 PM
troykshafer
May 31, 2011 8:07 AM
Neverdone
11
Apr 17, 2011 10:58 AM
lovesmonica
Mar 22, 2011 8:02 PM
bjthebetsig
Aug 26, 2006 12:24 PM
