Platform: A-, G-, & W-body
1996 Lumina AirBag Code Help! Please
Old Feb 19, 2017 | 10:28 AM
michaelchristinamiller's Avatar
Default 1996 Lumina AirBag Code Help! Please
Getting a 96 lumina from my grandparents. It has some airbag codes and am trying to figure out what might need to be done:
Error Codes:
#26 - Driver initiator circuit open
#21 - Driver Circuit REsistance High
# Defective DERM
I'm new to airbag codes and what the common problems are. Please help if you have any input.
Thanks
Old Feb 19, 2017 | 12:37 PM
kevinkpk's Avatar
Probably the clock spring.
Old Feb 19, 2017 | 3:56 PM
would a clock spring account for all of those codes?
Old Feb 19, 2017 | 4:42 PM
kevinkpk's Avatar
Resistance high, open circuit is just that. Yes. I had to replace the clockspring in my 96 lumina due to I cut the wire from the clockspring to the airbag after several times of having to get into the steering column. I replaced it with the same GM number off ebay. All I had was an airbag light on the dash.
Old Feb 19, 2017 | 4:43 PM
kevinkpk's Avatar
Have you been into the steering column?
Old Feb 19, 2017 | 5:56 PM
no. i am picking up the car in a few days. how can you tell if the clock spring needs to be replaced?
Old Feb 19, 2017 | 8:40 PM
kevinkpk's Avatar
Not, but the air bag is the only other thing in the equation. The codes that you have point to a open circuit. Air bag circuit is only (IMO) a faulty clock spring connection OR an air bag "problem". Dealing with this in my 96 lumina , was an airbag warning, clockspring from a 96 Olds fixed it, same GM part number I got off ebay
