2002 monte carlo PROBLEMS!
New User
Awaiting E-mail Confirmation
I have a 2002 Monte Carlo. I am having problems with my car not starting. The A/C and door locks do not work. I have replaced the fuses but they just blow again. If I use the key fob it will not work plus it will make my car not start. I have to disconnect the positive battery cable to get it to start again. Also my car will display locked in the radio and the car will not start. I have to disconnect the battery cable but leave it disconnected for hours before it will start again. Can someone please help me. I am a new member and I might have already posted this but I am having a issues navigating through here.
New User
Well I replaced the fuses for the fans and the door locks. They worked for a few minutes and then blew. I replaced them again and they just keep blowing when I use the door locks or if I don't they still blow. The fans worked for about 5 minutes and then blew when the car was running. The weird thing is, if I use the key fob, my car will not start. I have to disconnect the positive battery cable. Of course in the summer my car overheats cause the fans will not work. I have tried to relearn the key by turning the key to ACC for 10 min and then cutting it off for a certain amount of seconds. Doing that 3 times in a row. That didn't work. I have seen on the forums that a lot of people are having these problems. I hope someone finds a solution for all of us. Thanks for any information.
I have had similar problems with my 02 Monte. It would start when it felt like it. When it didn't, turn the key and nothing happened. When it did start, no gauges. Sometimes I would slam the trunk and it would start. Based on what I read on the internet, I replaced the BCM yesterday. Now the horn blows all the time and it won't start at all. For now I removed the horn relay. Still no start. I know it has to be programmed at the GM dealer, but I thought it would start long enough for me to get it there. Any suggestions?
Jr~
Dec 11, 2009 9:47 PM
