2006 mc ss p0521 & p0171
These codes were diagnosed on my 06 MC SS, Does anyone know where the oil pressure sensor or oxygen sensor are located. I believe these codes are related to the two sensors. If, so are they hard to replace. Would the Mass Air Flow Sendor have anything to do with these code. I took it Autozone and they gave me the diagnoses. Any suggestions or inputs would ge great. Thanks.
Autozone can read a code, and perhaps tell you what that code is. I don't know what 521 is, 171 is fuel system lean trim at upstream O2 sensor left side.
p0521 is engine oil pressure sensor performance....is your engine oil light/warning on? it won't turn on the MIL (check engine light) so if thats why you got it scanned then i'd focus on the lean code which has a lot of potential causes...5.3s have TSBs for clogged injectors so if you're going for a quick fix try a can of 44k and see what happens
