Platform: A-, G-, & W-body
97 chevy lumina dont know whats wrong.
Old Jul 26, 2013 | 2:18 AM
ub3rnoob's Avatar
Default 97 chevy lumina dont know whats wrong.
I have a 1997 chevy lumina that is leaking Tranny fluid out of a breather pressure tube(?) On top of the bell housing.I have not been able to find this on any diagrams and i am not sure if this is the correct name for it. There are no leaks anywhere else, any suggestions? I am looking for the best and cheapest way to fix. Also it will start and stop leaking randomly while idling and when i try to replace the fluid that was pushed out it comes up the fill tube. it is not over filled and I just changed the transmission filter.
Old Sep 12, 2013 | 8:50 PM
CONTECH's Avatar
When you say you just changed the transmission fluid, how did you measure your fluid when finished? Was the car running and in neutral and you checked the dip stick? You didn't fill the transmission till the dip stick indicated full with the car shut off, did you? Sounds like you have too much fluid. Someone else that knows more than me should be by later to help. Good luck.
chevyhelp
Aug 3, 2011 12:59 AM
codye3m
Oct 27, 2009 10:02 AM
sicksilverado
Sep 7, 2007 9:57 PM
muggelber78
May 25, 2007 1:37 PM
myztikaltrip
Camaro
Jan 30, 2007 9:16 PM
