Platform: A-, G-, & W-body
97 lumina 3.1 P1350 code
Old January 3rd, 2008 | 7:27 PM
davec166's Avatar
Default 97 lumina 3.1 P1350 code
hello,
i have a 97 lumina sedan 3.1 liter.....runspretty well for 120k......
i went for a sticker and the tech said i had a P1350 code. ignition control system.....it also said....or engine misfire.....the tech said for about 50 buck at the jy i could get another ignition control module with the 3 ignition coils as a whole unit. igot one andfirst i tested the primary and secondary of each ignition coil and the readings were right on as far as my book says. then i changed it out. before i did, i disconnected the battery. the check engine light is still on. my only question right now is....do i need to reset the code and shut the check engine light off with a code reader?
thanks,
dave
Old January 7th, 2008 | 12:27 PM
quinnman105's Avatar
Default RE: 97 lumina 3.1 P1350 code
Go to autozone and have them give yoyu a printout and have them re-set it. I had to have this done on my 2001 blazer yesterday
Old January 7th, 2008 | 9:58 PM
davec166's Avatar
yeah, thanks....i was thinking of doing that...will they clear the codes and shut the check engine light off for free?
Old August 9th, 2008 | 3:05 PM
cfrank's Avatar
ORIGINAL: davec166
Yes, they will all you have to do is ask someone behind the counter
Old August 13th, 2008 | 5:38 PM
00shortbox's Avatar
Either that or just disconnect your battery for 10minutes or so and then reconnect it, the light should be out when you fire it up.
JetSnake
July 14th, 2009 3:43 PM
dj59red
October 9th, 2007 5:39 PM
dj59red
October 9th, 2007 4:25 PM
syedea
July 26th, 2007 10:44 PM
MagicElectric
February 27th, 2007 4:42 PM
