Platform: A-, G-, & W-body
Code P0303 98 Lumina cyl. #3 misfire
Old Jun 13, 2006 | 3:13 AM
JetSnake's Avatar
Default Code P0303 98 Lumina cyl. #3 misfire
My wife's 98 Lumina with a 3.1 has been acting up in the rain lately. The engine misses and runs rough. I took it to the auto parts store where their scanner came up with a P0303 code, which is cylinder #3 misfire. The plugs and wires are not that old and they do look fine. But, it looks like the tower on the #3 coil might be cracked. I wanted to know if this is a common thing to happen or if this is the likely cause before I shell the money for a new coil.
Old Jun 19, 2006 | 9:39 PM
beckeruti's Avatar
Default RE: Code P0303 98 Lumina cyl. #3 misfire
moisture could be getting in it
common i am not sure
but anything could happen
i really dunno
good luck
Old Jun 19, 2006 | 9:43 PM
beckeruti's Avatar
maybe switch out the coil pack with another
if it is the kind i am thinking of it should work
then see if it misfires on another cylinder and if it does its that coil pack
this way u would make sure its that
Old Jul 14, 2009 | 2:43 PM
Bueno's Avatar
check fuel injector my 4 is misfire to and i just took it to a shop and thats whats wrong with it....
Lussorocuztoms
Aug 14, 2012 10:13 PM
69rrvert
Cobalt
Apr 28, 2011 9:42 PM
GoChevy
May 20, 2010 10:54 PM
philgethifi
16
May 27, 2009 11:52 PM
mazzov
Feb 21, 2007 6:14 PM
