Platform: A-, G-, & W-body
97 Lumina electrical problem
Old Nov 1, 2011 | 6:16 PM
SanRyder99's Avatar
Exclamation 97 Lumina electrical problem
Hello, I was at the store the other day and I went to start my car and I noticed a slight burning smell and a small bit of smoke coming from the steering column. I got a bit scared and immediately had it towed home. Now after not having driven it for a few days I went out to start it and it starts up fine, signals, lights, wipers, etc all work but I notice the temperature gauge stays at max and there is a constant chiming after the car is started and all doors are closed and seat belt is on. All other gauges work fine and the car seems to drive fine since I drove it up the street to test it. Any idea as to what happened, and is it safe to continue driving if I disable that annoying chime? Thanks.
Old Nov 1, 2011 | 9:56 PM
EinST's Avatar
Welcome to the forum. You obviously have an electrical short somewhere, not enough to blow a fuse (or is there a blown fuse?). I've also heard that some aftermarket fuse wouldn't blow at the rated amperage. If this is a disposable vehicle, go ahead and drive it but carry a fire extinguisher. If not, get it serviced before it catches fire.
MidnightIce
Jan 19, 2012 8:58 AM
lcrane85213
Oct 28, 2011 2:25 PM
spuddeth
Oct 16, 2009 3:38 AM
luminaguy
Mar 10, 2007 8:01 PM
benk17
Feb 23, 2005 9:52 PM
