97 Monte Carlo Dash light
i got a 97 monte carlo and the dash light that lights up all the numbers and spedometer is no longer lighting up. Is this a fuse problem, because i checked all the fuses in the fuse box inside the car by the passenger door. Could this be a burnt out bulb or did i maybe miss a fuse that was burnt out. Please help.
RE: 97 Monte Carlo Dash light
well if you checked all the fuses then it could be the bulb...i would check them all again...and on the back of the plastic cover that covers up the fuses is a diagram that shows/tells you what fuse controls what...
trewyn15
May 13th, 2010 1:04 AM
