Platform: A-, G-, & W-body
Air Bag cover on a '98 Lumina
Old Jan 13, 2011 | 9:27 AM
ClydeWigg3's Avatar
Default Air Bag cover on a '98 Lumina
How can I repair the air bag cover on the passenger side of my 98 Lumina? Right now it's hard from the cold. Can it be heated safely and re-glued? What steps do I take to make it safe to work on?
Old Oct 21, 2011 | 1:39 PM
gatorhead's Avatar
I have been searching for the same solution! If anyone knows how to remove that panle please post up instructions and a link if possible. If not a detailed instruction would be most appreciated. Is there any risk of air bag deployement by removal of this cover. I have found a replacement on a junkyard car, but I dont know how to remove and replace it. Thanks
Old Oct 21, 2011 | 5:12 PM
Drew82's Avatar
I found dash kits that basically bury the existing dash with a cover. Dollar for dollar they seem like the best route. You can google them pretty easy.
Old Nov 4, 2011 | 8:44 PM
gatorhead's Avatar
Figured I would stop back in with the fix since I couldnt find the answer anywhere on the net. I went to the junkyard and found one in good condition matching color and I used a large screwdriver and pryed the front right hand corner up and then the left. There are 4 snap sockets that hold it in place and it pops right up and pulls right out. It does have mesh type thing connected to the cover and the dash I guess to prevent it from being a projectile in the event of an accident. I cut that mesh away and replaced it with the new one. Took less than 5 minutes to remove and install.
Foxxtrot
May 15, 2015 1:03 PM
stayathomedad
Sep 30, 2014 11:28 AM
Jmiller3104
Oct 22, 2013 8:58 PM
scott_mckinney
Jun 24, 2007 2:48 PM
MarineSSgt
May 14, 2007 3:01 PM
