Platform: A-, G-, & W-body
DTC P0751 A/T 1-2 shift solenoid
Old Mar 23, 2024 | 11:30 AM
MarkJacobs's Avatar
Default DTC P0751 A/T 1-2 shift solenoid
Hey whats up guys, hope all is well. So i have a 02 MONTE CARLO LS and my obd scanner just gave me this code A/T 1-2 shift solenoid -No 1st or 4th gear (4T65-E), i was reading and it says the most common cause is because a clogged trany filter, dirty or low fluid, so I was wondering for this code will a simple fluid and filter change do the job or should I replace the solenoids as well I am not sure what to do but I dont want to take it to a shop and they try to have me pay for a big job that isnt even required. Also when i was checking my fluid level i smelled the dipstick because i read you can tell a lot about your car from the smell and it had a bad smell and some bubbles up by the level accuracy area. If anyone can please help me or give me tips on what I should do I would really appreciate it. Thanks guys, and hope you all have a great day.
I am a bit new to this so any help would be greatly appreciated.
Old Mar 23, 2024 | 11:48 AM
Photon440's Avatar
I would do the fluid and filter first, if that cures the problem then there would be no need for the solenoids. Which code was shown with the scanner?
Old Mar 23, 2024 | 12:18 PM
MarkJacobs's Avatar
The scanner showed a p0751 code on the OBD scanner
Old Mar 23, 2024 | 12:48 PM
Follow the troubleshooting here:
https://www.obd-codes.com/p0751
Old Mar 26, 2024 | 11:25 AM
MarkJacobs's Avatar
Default 2002 monte carlo LS p0751 A/T 1-2 SHIFT SOLENOID NO 1ST (4T65-E) OR 4TH GEAR
Someone said that my solenoids are in my transmission fluid pan so when I change the fluid I can change the solenoid as well, is this true because i am not sure where they are and I do not want to drain and replace the new fluid i just put in there if that isnt where its located. Again i have a 2002 monte carlo LS can you please let me know where to find the solenoids. Thank you.
Old Mar 26, 2024 | 12:22 PM
Yes the pan needs to be dropped to access the valve body. If you're not sure what you're doing then you might want to leave it to a professional.
Fluid can be captured and reused. But I would check the other possible causes first. Sometimes fluid can get into the electrical connectors.
00S102.2
Dec 29, 2022 11:12 AM
Owasso
Oct 5, 2016 7:25 PM
SethUpchurch
Oct 15, 2013 11:09 PM
hfdff
Jan 21, 2012 3:18 PM
jcw1500wt
Feb 22, 2008 11:17 PM
