Platform: A-, G-, & W-body
Heat Not Working on Driver's Side
Old Aug 6, 2016 | 11:17 PM
Kevin1974's Avatar
Default Heat Not Working on Driver's Side
I have a 04 Monte Carlo LS 3.4 liter and the heat will not work on the driver's side of the car. The AC works fine on both sides of the car. I've checked the fuses and can't find any bad fuses. Does anyone have any info on what might be causing this? Thanks!
Old Aug 7, 2016 | 7:40 AM
Check the blend door actuator for the drivers side. They are made of plastic and usually fail after time.
