Platform: A-, G-, & W-body
loud humming in the front end
Old Sep 9, 2010 | 12:48 AM
98chevymonte's Avatar
Question loud humming in the front end
i drive a 1998 monte carlo z34 and it has a very loud humming noise that i know it is coming from the front end, i have check all possible rubbing options even bought new tire. but the noise quits when i turn to the right but continues when i go straigth or turn left. Got any sugestions???
Old Sep 9, 2010 | 10:19 AM
garyjd's Avatar
have same problem on my 2000 monte carlo sounds like something is rubbing stops when i turn to the right
Old Sep 9, 2010 | 5:44 PM
yea i got it checked out today and the dude told me that its was the hub i think the driver side one, so i think ill get those replaced and go from there
Old Sep 11, 2010 | 8:14 PM
2wd-K5's Avatar
definately the wheel bearing, but if it happens when you turn left it is the pass side
Old Sep 13, 2010 | 12:36 PM
mikeythe613's Avatar
I have a chevy lumina and when i turned right the noise went away and it ended up being my passenger side hub assembly. Make sure its your driver side before you change it, it would suck to change both for no reason.
Old Sep 21, 2010 | 4:46 PM
im replacing both this weekend so ill let you know how it went
Old Jan 8, 2013 | 7:59 AM
Whiskey Still's Avatar
Did replacing the hubs help. I have the loud humming sound, but no change when I make a turn. I bought new tires and rotated to see if it was the tires. The garage says it might be a bearing, but he isn't sure.
custom_car_man87
Jan 27, 2015 1:07 PM
srmcnaughton@shaw.ca
Apr 23, 2013 2:59 PM
Mr.Cale
Jan 15, 2012 5:39 PM
gmck
May 5, 2010 8:58 PM
cdeal
Aug 19, 2008 6:45 PM
