2001 corvette wheel hub replacement
Old Jun 1, 2018 | 4:53 PM
old and poor's Avatar
New User
Awaiting E-mail Confirmation
Default 2001 corvette wheel hub replacement
i receive messages on the odometer area on my 2001 vette saying " service abs brakes, service traction control". Dealer says that this means i need new wheel hubs. Is this accurate. Can just one be replaced, how do you or can you just check if this is the problem. HELP
Old Jun 1, 2018 | 10:39 PM
if the wheel speed sensor reluctors are part of the hubs.....and if there is play in the bearing...it will set abs codes. Yes, just one hub can be replaced.
If you want to check for a bad hub; raise the tires off the ground and check for play in the hub
can't report on their diagosis based on the limited information and this is over the internet.
YES, a bad hub can set abs codes. Is it your problem...maybe. Any hub with play is a safety issue and needs replacement asap.
