4x4 problems help
Old Nov 13, 2018 | 4:35 PM
Quackaddict1011's Avatar
Default 4x4 problems help
i have a 04 chevy silverado 1500 1/2 ton i have replaced the transfer case shift motor the front axle actuator the selector switch the control module cleaned the grounds checked the 4wd fuse and i still cant select nothing on my selector switch it runs it cycle then goes dark it has auto 4wd running out of options rather not take to a shop has any one ran into this problem please help
Old Nov 20, 2018 | 4:23 PM
Perkins315's Avatar
Default Same
Im having simular problems
Old Nov 20, 2018 | 4:29 PM
i got it figured out what was going on was the computer was fighting it self i had to put the truck in nutrual and input a new transfer case shift motor and it fixed my problem the truck was saying it was in 4 hi and the transfercase motor was saying it was in 2wd if u pit the truck in neutral u can also take a pliers and shift the transfer case to get it lined up which is a pain in the butt
Old Nov 20, 2018 | 5:39 PM
Perkins315's Avatar
Default Sweet
Thanks for the reply.. Does your front drive shaft always spin? So you had the transfer case motor off while plugged in and shifter truck to Neutral and t-case to Neutral with pliers? Correct?
Old Nov 20, 2018 | 5:44 PM
i had my my front drive shaft from the tcase to the front diff out tcsm out put truck in neutral and u should be able to shift tcase into neutral mine was the star fitting so i had to be careful not to strip the splines macanic said put a shop rag between pliers and tcase so u dont stip tcase splines for the tcsm
