99 Silverado iac valve problem.
Old Sep 9, 2018 | 10:55 AM
Joe098's Avatar
Default 99 Silverado iac valve problem.
Hello my name is joe I have a 99 Silverado with 192xxx miles 5.3l about a month or so ago it would have a idle issue to where when it would start it would jump to about 3000rpm then down to around say 100 or 200 then would idle back up at 700rpm I asked around town and came to the conclusion it’s the iac valve so I replaced it and reset it following the instructions in the package. It worked for a couple days perfectly fine until last night, I got off work and the truck was cold I went to start it and it started then died right away so I tried a couple more times with the same outcome the only way I could get it to idle was to hold the gas down to 1200rpm till it warmed up and it would idle but really rough does anyone have any ideas? I’ve done a lot of research and couldn’t find anything to go off of. New parts it has since this problem occurred fuel pressure regulator, Pcv valve, throttle body gasket, and I did the intake gaskets a couple months ago.
Old Sep 11, 2018 | 6:39 AM
oilcanhenry's Avatar
Have you checked for any OBD II codes yet?
Old Sep 11, 2018 | 6:42 AM
Joe098's Avatar
I have and that’s another weird thing it does so when it acts up the cel comes on but it’s only a Evap canister code and a o2 sensor code.
